Ricoh MPC2030 Data clear
  • Kenny
    • Jun 2009
    • 538
    Hi have a customer with the above machine and they want us to data clear it as they are a solicitors and there old information needs removing, we don't work on Ricoh so could do with some help before we visit
    Many thanks
    Kenny
  • lilleputte
    • Jan 2013
    • 153
    Re: Ricoh MPC2030 Data clear
    Hi.
    if you want to delete information , just format the hard drive and reboot the machine
    • Kenny
      • Jun 2009
      • 538
      Originally posted by lilleputte
      Hi.
      do I need a service code ?
      Thanks for your help
      • lilleputte
        • Jan 2013
        • 153
        Hi.
        1. Go to service-mode , yellow-107 and hold stop for a few seconds
        2. Press copy-sp
        3. Press mode
        4. Go to "Format hdd" and choose "1" and execute
        • Kenny
          • Jun 2009
          • 538
          Hi.
          2. Press copy-sp
          3. Press mode
          great thanks
          • Kenny
            • Jun 2009
            • 538
            Originally posted by Kenny
            great thanks
            sorry for been an idiot, not gone to site yet but how do you get in service mode is it simple ?
            • Kenny
              • Jun 2009
              • 538
              just re read first post !!!!! sorry
              • Gift
                • Mar 2011
                • 2459
                HDD format is ok as a first step but does not remove all customer data - you should also perform "memory clear", you can found it within sp group 5 (mode). If you open this SP you'll find several options - don't chosse "all" - start with IMH and then all other below IMH, this way you'll keep some important engine related parameters like CCD/laser values. If the machine is equipped with a fax card you also should enter fax sp - clear data - factory reset (or something like this).
                • Kenny
                  • Jun 2009
                  • 538
                  Sorted thanks for the help chaps !!! much appreciated
                  Kenny
