Samsung Scx-6320F
  • williekriss
    • 39
    Samsung Scx-6320F
    what is the problem for
    -open heat error.
    -when want to copy document,press start then copying,after that machine restart back to warm up..please wait.
    • 23009
    The thermal fuse in the fuser is probably blown. It could be coincidental, or it could be caused by the power supply.
    The first thing you'll need to do is determine the extent of the damage to the fuser. If it's an all-out meltdown, and the rollers are fused together, you'll have to order the fuser unit at least.
    You should get yourself a manual. =^..^=
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
      Paul@justmanuals.com
      • mike*
        • Jun 2010
        • 58
        Yup fuser. The 6322 and the 6122 both had main board problems they were blaming for the fuser issues. Of course after they redesigned the fuser then blamed the power supply for the problems....
        • printsnow
          • Oct 2010
          • 24
          Yeah, had the same thing happen on the 6322 last week. Samsung said to replace the MCB & Fuser, then if that failed put in a power supply. Agree with Mike*, I think they were trying to put the blame on one part, then another one.
          • williekriss
            • 39
            Thanks guys,i will give try today and give a feedback soon.Thanks for the SOLUTION...^_^
            • williekriss
              • 39
              Hi there,i already try to change fuser unit and power supply board,no more open heat error,but why when i want to copy the machine can restart itself?
                • 23009
                Do you mean that the machine reboots when the Start key is pressed?
                • mjunkaged
                  • 386
                  Check your firmware, and update even if it's newest version.
                  SOP for Samsung weird problems.
