SCX-6345 getting a lot of black lines on the scanner glass.
  • krm
    • Aug 2009
    • 233
    Sometimes there is visible stuff on the glass and other times it's not. It will go away with cleaning and come back shortly. They are not using white out or anything else I can see. Anybody experience this and come up with a fix?
    Thanks in advance.
  • ZOOTECH
    Senior member of CRS
    • 3374
    Re: SCX-6345 getting a lot of black lines on the scanner glass.
    Thanks in advance.
    If you have access to silicon oil, wipe the glass down and then buff it out.
    • krm
      • Aug 2009
      • 233
      I use brillianize and that usually does well, but not at this place. Where can I get that oil? By buff out, I'm assuming you mean put a drop or two on and just buff until it's super slick? Has this worked on this type of problem for you?
        • 22932
        Try increasing the spacing between the white plate and the slit glass. Usually there are spacer features at the front and rear of the DP white plate. A simple approach is to add a few layers of self adhesive mylar to add 1/3 of a mm per layer. Same spacing front and back.
        I've done this on a wide variety of machines when you get stretched images or frequently dirty slit glass.
        Personally I don't endorse the fuser oil approach. I think it just collects particulate and gets goopy.
        • ZOOTECH
          • 3374
          Yes, a drop or two only, and buffed out.
          Sharp has a p/n for a silicon oil that I don't think is fuser oil, it's a lot lighter, and doesn't collect dust or gum up like I think fuser oil would.
          The height adjustment Blackcat mentioned is worth looking at.
          • krm
            • Aug 2009
            • 233
            Thanks. I will take a look tomorrow. I'm desperate on this one. Customer is sick of the lines. How many per side?
              • 22932
              ... How many per side?
              It'll depend on your self adhesive mylar. Maximum 0.3 to 0.5mm total spacing between the white plate and the glass. =^..^=
              • krm
                • Aug 2009
                • 233
                Thanks.
                Deep cleaned the scanner and all areas today. Added two pieces mylar to the "resting areas". Two each side.The mylar I had was the one for the doc feeder on the BHDi250 series. Yeah, that ancient machine. Those guides got damaged a lot. That seemed about to your specs. I shall see what happens. I think these fast machines have trouble processing the high volume accounts. They had a BH 222 there and never had these scanner glass issues.
                  • 22932
                  Time will tell.
                  Too little spacing causes jamming and frequently dirty slit glass.
                  Too much spacing causes a blur at the leading or trail edge, usually trailing edge. Or blurry images.
                  • Canuck
                    Tech Specialist
                    • 1713
                    Replace the glass. Cheap soft glass. Run shading correction
                    • RookieTech
                      • Jun 2008
                      • 46
                      Anyone find a fix to this issue? I am having the same problem with SCX-6545N (newer) model.
                      • krm
                        • Aug 2009
                        • 233
                        Black Cat's mylar helped a lot. I placed them directly on the glass at extreme ends of scanner glass. Clean with alcohol and brillianize the glass and plastic. I also left the customer a rag and cleaner + instructed them. They still have issues, but not as often. I have one 6545 that is like yours. The MFG has no ideas.
