SCX-6545N image unit dirty prints
  • TTL
    • Dec 2008
    • 127
    Hi people,
    In one SCX-6545N the prints are coming dirty, changed the image unit, it's good for about 10.000 print and then the prints are dirty again. The bag waste in the toner sometimes is totally full too. The copy its dirty because the toner falls from the rec blade.
    Already change 3 times the image unit, its ok from 10k to 20k but always making the same.
    Some idea?
    • 23008
    Re: SCX-6545N image unit dirty prints
    Generic toner? =^..^=
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
      Paul@justmanuals.com
      • TTL
        • Dec 2008
        • 127
        The toner is original.. And I have the manuals..
        • Iowatech
          Not a service manager
          • 3930
          What are they printing on? Kind of sounds like the waste toner management system is getting plugged by dust from extra dusty paper. Or there is something else causing it to get plugged.
          Are all the fans working? Could be that the waste toner is getting cooked by a non-operational cooling fan.
          • krm
            • Aug 2009
            • 233
            Originally posted by TTL
            Hi people,
            Some idea?
            Some of these are experiencing bad toner causing gritty copies and smudgy print.
            • Canuck
              Tech Specialist
              • 1713
              There are defective toner cartridges from Samsung. The port for the waste toner from the drum on the drum unit does not open fully. Waste supposed to go back into waste area of toner cartridge. It is opened by insertion of the toner cartridge. Waste backs up in drum and dirty copies result. Eventually grinding noise. You pull out drum unit and can't even turn the drum. Samsung issued a bulletin about this a few years ago. See it on 6345,6545,6555
              • krm
                • Aug 2009
                • 233
                I would love to see that bulletin if anyone has it to post.
                • Canuck
                  Tech Specialist
                  • 1713
                  I'm on my laptop now. Don't have it but I got it on desktop at office. I'll post it Tuesday(Monday Thanksgiving here!)
                  • krm
                    • Aug 2009
                    • 233
                    Great. Thank you!~
                    • Canuck
                      Tech Specialist
                      • 1713
                      Here is the bulletin...
                      • krm
                        • Aug 2009
                        • 233
                        Thank you! Any idea what is going on with the 6545 machines? I'm getting the same problems. The new model would have this problem rectified? Grinding noise with new toners, gritty copies. Replacing toner usually works.
