5935 "open door"
  • lunar
    • Mar 2013
    • 8
    5935 "open door"
    Op panel says "Door is open. Close it" Any ideas to correct. Customer is not for profit and can not afford to replace it.
    • 22997
    Re: 5935 "open door"
    What have you done so far? =^..^=
    • livewire
      • Sep 2011
      • 608
      Check PMO-ACTUATOR CVR OPEN PN:JC72-00974A
      • lunar
        • Mar 2013
        • 8
        Opened and closed the doors, front and fuser (external and internal). Actuacted switches with screwdriver to make sure they were being actuacted. Turned off and on and unplugged. No difference.
        • copytechman
          • Nov 2008
          • 929
          Had 1 of these do this and it was the HV board under the machine where the front cover interlock is fed from.
          Regards!
          A!
          • lunar
            • Mar 2013
            • 8
            Tried replacing that board on a 5530 and all of the plastic posts discentrigeated. Nothing to fasten new board to. New copier time. Will keep trying and post if I get it fixed.
            • copytechman
              • Nov 2008
              • 929
              Yup had that happen to me too... Glad I never had to many of those out there!
              Regards!
              A.
              • lunar
                • Mar 2013
                • 8
                I have stopped selling the Samsung, to many weird problems and can't fix issues. Got the line because it was cheap to compete with the big box stores. If customer buys it from big box and it breaks they throw it away. If they buy it from you and you keep it working 5+ years and it breaks and you can't fix it they're mad. No more.
                • copytechman
                  • Nov 2008
                  • 929
                  Odd, the 5935 has been one of our most reliable models. Nice compact and fast machine with a nice user interface to boot..
                  Regards!
                  A.
                  • lunar
                    • Mar 2013
                    • 8
                    Ordered the HV board today. Will let you know the results. Thanks for all the help!
                    • aficio63
                      • Jun 2014
                      • 36
                      I know this is an old post but did the HV board fix problem??
