Sharp ARM237 getting XX-XX error
  • theprinterguy
    • Jun 2011
    • 18
    [Error Code] Sharp ARM237 getting XX-XX error
    Hello,
    I have a Sharp ARM237 getting error coed xx-xx. any ideas? worth looking into?
    Paula
  • danceswrabbit
    • Dec 2013
    • 65
    Re: Sharp ARM237 getting XX-XX error
    Is there a code instead of the xx-xx? is it something like h4-01 (or some other alpha numeric code) never seen xx .
    • theprinterguy
      • Jun 2011
      • 18
      Re: Sharp ARM237 getting l6-10 error
      Hello,
      the error L6-10
      please help!
      Paula
      • danceswrabbit
        • Dec 2013
        • 65
        OOOOO bad polygon motor in the laser unit. Laser unit on this isnt bad to replace. I think the part # is DUNTK0384RSZZ. for the whole lsu.
        • brewster67
          • Jul 2011
          • 167
          Most times you can change just the polygon motor PN: RMOTN0028QSZZ. It is a little cheaper than the whole unit.
          • skookumchuck
            • Feb 2012
            • 62
            I always just replace the laser unit after getting just the laser board and finding that was not the problem.
            • theprinterguy
              • Jun 2011
              • 18
              I Love This Help from Everyone....
              Thanks,
              If I get that Laser Unit ordered, can someone help me with Installation instructions?
              Thanks,
              Paula
              The Printer Guy, Inc.
              • harleyrider
                • Oct 2011
                • 348
                it is pretty simple on that model. Take the center exit tray off and it is under there. 4 screws and your good.
                  • 23010
                  Just remove the four screws that secure the laser to the body, but don't lift just yet. Make sure all four corners are free, especially at the rear. There are two alignment pins at the machine rear that can break off if you tip the laser back when lifting. Comprende? =^..^=
                  • ZOOTECH
                    Senior member of CRS
                    • 3376
                    You will have to remove the rear cover to disconnect the LSU cable. To reach the two rear screws, tilt the MCU back by removing the screws for the pwb holder, and disconnect the connectors at the top of the pwb.
                    You'll see the screws for easy removal with a long blade screwdriver.
                    Good warning BC, I never thought those locating pins could break off.
                      • 23010
                      I only did it once. It was a surprise to me too, and it's more difficult to position the laser correctly without those pins. =^..^=
                      • harleyrider
                        • Oct 2011
                        • 348
                        you don't have to take the back off on this model. If it were a ar 205 then yes the laser screws are hidden behind the board. This model is too easy. Maybe 10 minutes at the most.
                        • theprinterguy
                          • Jun 2011
                          • 18
                          Could you give me detailed instructions for replacing the Laser Unit?
                          Paula
