Just remove the four screws that secure the laser to the body, but don't lift just yet. Make sure all four corners are free, especially at the rear. There are two alignment pins at the machine rear that can break off if you tip the laser back when lifting. Comprende? =^..^=
You will have to remove the rear cover to disconnect the LSU cable. To reach the two rear screws, tilt the MCU back by removing the screws for the pwb holder, and disconnect the connectors at the top of the pwb.
You'll see the screws for easy removal with a long blade screwdriver.
Good warning BC, I never thought those locating pins could break off.
"You can't trust your eyes, if your mind is out of focus"--
I only did it once. It was a surprise to me too, and it's more difficult to position the laser correctly without those pins. =^..^=
you don't have to take the back off on this model. If it were a ar 205 then yes the laser screws are hidden behind the board. This model is too easy. Maybe 10 minutes at the most.
