I compared the parts lists and everything appears to be identical except the heat roller, pressure roller and pressure springs. Does anyone know if this makes a huge difference. I have dozens of 275's but only about 3 208's. Thanks.
Sharp AR275 vs AR-M208 Fuser
I'll have to differ on this one. The AR-275, AR-M275N, & AR-M208N all have slight variations. I haven't tried swapping them, but I doubt that they'll fit up. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
I had no choice but to try the 275 fuser in the 208 and it seems to be working fine. The thermistor is the same so I suppose that the temp is also the same. If there is a pressure difference I can't tell. The toner is the same so fusing performance should be also the same. Anyway, thanks for your input. I will repost if anything develops.Comment
