MX-3070-4070-5070-6070N
  • Alpanapa
    • 20
    #16
    Re: MX-3070-4070-5070-6070N
    or maybe this will help
    See attached bulletin
    • SpYdAsWeB
      #17
      Hi chaps,
      there is now an official modification for this. See the new bulletin attached...
      • Toner Boy
        • Aug 2007
        • 357
        #18
        Hard to believe we're having to deal with this again, had same issue with 3501's and dummy punch mylar way back when. Total dejavu
        • branjake
          • May 2016
          • 7
          #19
          We have been having multiple problems with these finishers, still waiting on a fix.
          • 1090tech
            • Jan 2018
            • 8
            #20
            We had this problem with a 3070 and it turned out to be the customers choice of paper. They used bargain bin paper from that came out of the fuser with excessive curl and jammed where the customer could not reach it. We got them to use higher quality paper and the the machine stopped jamming.
            • superssport
              • 11
              #21
              Went out to one yesterday to help a tech. Was said to constant jamming for months . It would jam right at the entry of the finisher. I looked up at the photo sensor at the entry of the finisher and it look foggy. Cleaned sensor and now it's jam free. Tech called later that afternoon and still no jams.
              • boutn
                • Jun 2016
                • 540
                #22
                I had a machine with internal finisher which sometimes gave POD2_S.
                Turned out the plastic inlet guide of the punchunit was uneven. Production error i guess.
                I had to disassemble it and with a bit of fine sandpaper make it smooth again...
                No more jams after that.
                • jp74msj55
                  • Oct 2014
                  • 146
                  #23
                  Originally posted by jerrysandstrom
                  Hi
                  I hade the same problem with internal finisher it was jamming on FNPS1_S .check out the bulletin, i changed the spring in finisher and it worked for me.
                  //Jerry
                  Sweden
                  The old inner finishers didn't have the mylar strips that are included in the new ones. Tech pub about adding the mylar strips
                  to prevent jams. Have had many of these that needed the mylar strips installed on the inner finisher.
