Sharp MX3501N no toner to some DV units
  • Sam Tofu
    • Dec 2007
    • 130
    [CQ] Sharp MX3501N no toner to some DV units
    Blk meter 278K Color 77K
    Initially Cyan DV almost void of toner. Checked TONER motor was OK. Changed Sensor, no diff. Changed DV UNIT with used with low meter. ALL seemed OK.
    (Just in case customer hadn't shook toner properly, put that one aside and put in new cyan toner.
    2 weeks later (~300 copier color made) call with magenta doing same. Went through same process. Put in used low meter magenta DV. All OK .
    Now 500 color later got call that cyan doing same. Toner motors still OK. pipe for toner into DV unit not clogged.
    BTW, customers color is not a heavy fill probably only 2 to 3% (I mention that in regards to number of copies before issue came back on Cyan)
    Not certain if High Volt of PC board could be issue.
    ANY IDEAS GREATLY APPRECIATED
    TIA
  • copierdude1114
    • Dec 2015
    • 29
    Re: Sharp MX3501N no toner to some DV units
    Have had some issues like this, that particular customer likes to store their toners vertical literally have to bang the toner on the ground to break up the rock that has formed in the bottle.
    • Ditchman
      • Feb 2011
      • 51
      Change the drum unit first before you try anything else
      may be electrode cover leaking also!
      • nottoosharp
        • 266
        This happens all the time. My favorite are the f2-02 codes from people storing their 450nt on end and only running 500 a month so the toner compacts for a year. Trashes the DV sometimes the toner motor, and always makes me want to poop in the trash can.
          • 22999
          When I have customers that run minimal color, I suggest that they run a developer refresh (only a single time) once a week.
          Essentially what happens is the color developer dies from lack of use. If you agitate it once in a while it lasts considerably longer. =^..^=
          • nottoosharp
            • 266
            Couldn't they just run a few color prints instead? I ask because I do my level best to keep my customers away from the service menu.
              • 22999
              Developer Refresh is a user function in the System Menu. No need to access Service Menu, no need to even log in as Admin. And it's near the top of the menu: System > page 2 > Adjustment/Maintenance > page 2 > Developer Refresh.
              Oops! This is a Sharp thread! I misread this as a Taskalfa KM-3551. I suppose you could do 25-01 if that still exists in the service mode. Now I see what you mean. Sorry. =^..^=
              • nottoosharp
                • 266
                It sure does, but I'm not letting my customers into service. Especially on anything newer than a 3501. That's all I need is some smart guy that thinks he's tech savvy because he looked up how to use the charge cleaners messing with my sim settings. Lol
