Error code reset on Sharp AR-C260m
  • Tonerspill
    • Sep 2025
    I have an H-3 code on a Sharp AR-C260m and I've reset the thermostat and cleaned out the fuser jams but the sequence to get into the service mode is different from when I worked on the older Sharps. I was used to the CROP or CI0I method but I don't know how to get to sim 14 on this one to test out the fuser. Any help would be appreciated.
    • 23010
    Only slightly different:
    #/P > * > C > * > 14 > Start > Execute > Yes > CA
    • OMD-227
      As well as resetting the thermistat, check for toner/paper dust buildup on the contact thermisters for each roller. Also check the lamps. I have had this error many times before, reset it, machine works fine..... but turns into a recall for same error again next week due to either of the above. Check it first time to prevent another call.
      • Tonerspill
        resetting error code
        Thanks for the replies, I'd used the sequence you mentioned already and still couldn't get into service mode. I ended up starting the machine with the fuser slid out, that was the only way it would let me get in and put in the simulation 14. Once I did that, it warmed up normally and worked as advertised.
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1902
          C260 H4
          Check BOTH the upper & lower thermistats. The lower heat roller will pickup enough heat from the upper that it will run with the lower thermistat popped. Eventually, you'll get another H4. Hope that helps.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
