AR286 drum scratched (tiny spot on it)
  • jinjangu
    • Jul 2008
    • 39
    I have experienced few of such cases, the drum's surface has many tiny mark distributed all over it (it can't be removed, it is not a stain. it is a scratched mark, very tiny, as big as a sand). so when photostat, the copy also has tiny spot on it. it looks like the mark of developer,but i have no idea what make this mark. anyone know it, pls let me know. keep replacing the drum is very cost
    • 23010
    I assume that you've ruled out label adhesive on the drum.
    If it truly is pin holes, that is caused by arcing. Arcing that could come from the primary charge, the transfer charge, or the mag roller. I would probably start replacing parts in that order.
    If you've replaced several drum units, the primary has been changed a few times already. =^..^=
    • Toner Boy
      • Aug 2007
      • 366
      Check the developer unit. The gap may be too big (mag brush too high, rubbing on drum surface). Also contaminants in the DV could be damaging the drum in conjunction with the gap problem. Check the spacer collars for wear or lock-up and inspect the rear drum DSD aluminum flange where the collars ride for pitting. One time we had to change the toner hopper unit suspecting it was warped and contacting the drum surface.
      Some or none of these may apply.
      • jinjangu
        • Jul 2008
        • 39
        thank you both of your info.
