AR-M237 scan to folder setup
  • CCC Repair
    • Sep 2014
    • 47
    [Misc] AR-M237 scan to folder setup
    I am trying to setup an AR-M237 MFP for either scan to folder or email and it appears I am missing a step or something. I have no problem setting up MX models but this is older model and the web interface page is different. When I go to scan something it comes up with error message stating can't locate server. Any help with this would be greatly appreciated....Thanks
  • JLSam
    • Jun 2015
    • 605
    Re: AR-M237 scan to folder setup
    Save yourself a headache, use Sharpdesk.
    Sent from my ONEPLUS A3000 using Tapatalk
    • ZOOTECH
      Senior member of CRS
      • 3375
      JLSam is right, scanning to SD is easiest, but you will need the Network Scanner option enabled.
      • CCC Repair
        • Sep 2014
        • 47
        I would love to use sharpdesk except I'm not an authorized technician with them. Although I used to be and I have used sharpdesk in the past. I don't have a copy at the moment or the license that you need to use it.... so I am having to do this the hard way
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1887
          It's been quite a while, but I don't think the AR-M237 will scan to folder (SMB).
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
            • 23009
            I seem to recall that you need to buy a license. The demo mode is only good for 30 days, then you have to set it up again. =^..^=
            • lky1978
              • Mar 2009
              • 483
              Not 30 days but 500 times only.
              You can make it work via scan to ftp
