AR5631 fax problem
  • petrus
    • 155
    AR5631 fax problem
    when i sending fax using RSPF,the customer received a blank paper.but if i using on scanning glass its ok.
    what is the problem.
    I am new on this machine .so I didnt have much experiance.
    any idea are very appriciated.thanks
  • NCArt
    Mountain Tech
    • May 2008
    • 81
    Was the original face up???
    • petrus
      • 155
      Yes,the original was face up.Making copies no problem only faxing.Actually I cannot complete adjusted the SP-53 cause I dont have the service manual for this model.
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1887
        66-3 will check the fax memory. I think it's the same as you're working on. Hope this helps.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • petrus
          • 155
          this is brand new machine.I have execute 66-10 ( image memory clear)
