need help on whites lines on different developers ,
have 2 copiers to test with ,
when running test print , not off glass, directly from printer , getting whites lines on cyan and magenta ,
tried new units , same problem, move unit to another color slot , (modify cart slightly , ie swap cyan for yellow ) , problem follows cartridge
not really an experienced sharp tech , but putting cyan with problem into 2nd copier prints fine , so in one case problem seems to follow cart in same copier , but not to another machine ,
i know when they are installed a adjustment is run , my only concluion is bad develpoers or ANOTHER ADJ LIKE TRANS OR DEV BIAS?
ANY HELP?
ANY HELP?
