Sharp MX2300
  • Armenator
    • Jul 2025
    Sharp MX2300
    HI
    I keep gettin Error code E7-01,
    I replaced the MFP board,and HDD also i replaced the main board
    i can print with the machine as a network printer but as soon as press the print key i get the E7-01 Error code
    any suggestion??
  • mrfixit
    Senior Technician
    • Sep 2007
    • 83
    if your saying this only happens when copying what happens if you try to scan to pc?
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1885
      Just curious if you've run this by the guys on the hotline? You can get some numbnuts & some pretty knowledgeable ones. My guess would be a defective EEPROM. If you worked on Cougars, a bad EEPROM would give odd error codes. Although I did get a bad main PWB from board repair, sent it back only to get the exact same frickin PWB back. The next time I kept it, ordered the replacement, then sent it back after I got the other one. HTH
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • Armenator
        I have no problem with scanning to pc it works fine
        • Armenator
          thanks for info, just one more question, i have to get an EEprom from Japan? or there is way that i can update that EEprom?
          • tmaged
            • Oct 2008
            • 1885
            I imagine you'll have to contact Sharp DSSD to get an eeprom. I believe that eeprom has counterfit protection with serial number info so you can't program one or anything like that.
            Hope that helps !
            -Tony
            www.dtios.com
            • petrus
              • 155
              if you suggest to send the eeprom to sharp centre to re-program ,makesure to take both of the eeprom from your machine.if I am not wrong it located one at scanner pwb and one at main pwb.also please print out the machine self info data.you need to send it to japan through thair local sharp service centre.also please attech the machine serial no.
              • mrfixit
                Senior Technician
                • Sep 2007
                • 83
                make sure you update firmware to the latest version before you call them, that's the first thing they'll ask you before they'll do anything and the first guy or 2 you talk to won't know anything
                • user245470
                  try the mem chips
                  i have seen the mem chips on the exntire color mx line throw e7 codes one mem stick is for copier mem and the other ones are for scan and print. i cant remeber which one is for copy though so rp all
                  hope this helps
                  you friendly neighborhood gold master tech
                  • NCArt
                    Mountain Tech
                    • May 2008
                    • 81
                    I had this problem awhile back.....I replaced the DIMM 4 memory as I was advised by my Field Rep. I got the DIMM from Memory Experts and it fixed my E7-06 error.
