ar-m450n L6-10
  • DINGO
    • 661
    ar-m450n L6-10
    Helo
    Y have a ar-m450n that every mornings when swicth power on give me L6-10??
    Y turn powr off and conect again and works well every day.
    Can someone help me??
    thanks
    • 23009
    The laser is failing. =^..^=
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1887
      The polygon motor is more than likely the culprit. Replace it or the entire laser unit to avoid other issues. The early serial numbers were a real pain to replace/repair. The later serials are relatively easy, especially without a FN-6. Hope that helps.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • DINGO
        • 661
        RE
        Tmaged
        y'haved tested whit 61-1, and gives me ok??
        y apreciate greatly yours help.
        thanks
        • tmaged
          • Oct 2008
          • 1887
          The result is OK only because your problem is intermittent. If the Polygon motor fails completely, the result would be NG.
          Hope that helps !
          -Tony
          www.dtios.com
          • DINGO
            • 661
            RE
            OK
            y`m whith look because the problem only gives in morning in the first power on, but tmaged, y don`t urnderstand what you mean whith NG?
            by
            • tmaged
              • Oct 2008
              • 1887
              LSU test 61-1 will either yield results of OK if the test is positive, or NG (no good) if the test fails. Your test results in OK as the LSU has not completely failed yet.
              Hope that helps !
              -Tony
              www.dtios.com
              • DINGO
                • 661
                re
                Ok
                y understand now.
                thanks
                stay weel
