Sharp AR-M355 Fuser Issue - Still
  • Tech2002
    • Aug 2008
    • 334
    Ongoing issue. Streaked copies - Dirty Cleaning Roller. Cleaned Cleaning Roller - Replaced Cleaning Roller, before that replace DV Unit and Developer. Still having issue with Dirty/Streaked Copies.
    Change Fuser?
    • 22995
    Install the heat sink roller from the AR-M350 (NROLM1387FCZZ). It's a solid roller over the whole length of the roller, so it will clean the whole roller, not just 25mm sections. =^..^=
    • Tech2002
      • Aug 2008
      • 334
      Thanks for the reply - I tired your suggestion, but it didn't take. Client is telling me streaking still occuring. Not sure short of changing Fuser what else to try. There are new Upper & Lower Heat Rollers. Developer is new. Unless maybe the Upper Heat Roller is bad.
        • 22995
        Are these OEM rollers & toner?
        I've seen occasions when aftermarket toner has caused this. Some of the aftermarket rollers can do this, even when new.
        How about something oddball, like the customer that runs a lot of linen paper stock? The toner in the little valleys can stick to the fuser rollers.
        Have you been fiddling with the fuser temperature? If the temperature is too high or too low, you can get the same effect. The first thing that I'd do is restore the fuser temperature defaults.
        Do any of these sound familiar? =^..^=
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1866
          Do you have it narrowed down to the fuser ?
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • Tech2002
            • Aug 2008
            • 334
            Yes - I changed out the DV Unit and Developer thinking that was the cause. Then, rather than going the expense of a Fuser I change the UH Roller again to see if there was an issue with it. Won't know if this is a fix or not for about a week or so. The build up usually occurs when they're doing a heavy copy job.
