MX2610N DC Power Supply swap w/mx2640 ??
  • Toner Boy
    • Aug 2007
    • 365
    Brown-out killed DC Power. No PWB in stock, anyone try this swap? P/N's are different for sure.
    All connectors are the same, I've hooked up most connectors to verify power restores but don't want to kill machine by plugging all in and running it.
    Will have to pull machine and install loaner if can't fix quickly...
  • moose55
    • Mar 2017
    • 143
    Re: MX2610N DC Power Supply swap w/mx2640 ??
    All documentation that I see has different part #'s. The connectors may be the same, but something is different. You take your chance by powering it up!
    The Moose is loose!!
    • repn1999
      • May 2010
      • 310
      I would not do it. Swapping electrical parts between series is not a good idea and will most likely cause wierd issues that are almost impossible to troubleshoot.
