sharp 450 E7-11
  • jpcopy
    • Apr 2006
    • 256
    sharp 450 E7-11
    I know it the shading trouble but what to do to correct. I cleaned all optics real well. went to 46-17 and where to from there. In book there is a 63-2 for used to execute shading. when I entered, machine gave me a message TROUBLE (E6-14) which is CIS-ASIE COMMUNICATION TROUBLE.
    anybody with any suggestion on which way to go from here? just hoping it something simple. anyway appreciate any info
    jp
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1887
    Assuming the lamps are coming on, I'd check the pins in the EF-1 connector. If they're good replace the harness between the EF-1 as these are known to cause problems.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
      • 23008
      tmaged is right on the mark as always.
      The connector from the scanner to the MFP PWB can be poorly connected or a pin bent. Also the internal harnass for the EF1 is known to cause a wide variety of CIS related problems affecting side-2 only. =^..^=
      • lobbelios
        • Oct 2008
        • 5
        Another thing to check is the Mother PWB. It can cause all king of strange problems and E7-11 is one of them.
