Sharp AR M277 Black Copies
  • mlbcopiers
    • Oct 2007
    • 34
    I have a customer with a Sharp AR M277. The copier is used rather heavily. The customer called saying the copies are all black, and the replace toner message was on.
    The exposure is ok. The developer setting showed 169. I had this problem once before with this copier, and did a complete PM and the machine worked fine. I thought that some toner had shorted out the transfer roller. Everything I did today has not corrected the problem.
    I replaced the DV (setting 139), the drum, the toner, and the transfer roller. I even exchanged the tranfer roller door. The drum seems to coat itself, and the developer unit seems to overtone itself. I pulled the transfer roller, and the drum seemded clean.
    Could it be a "bias" problem. I checked all the spring connections to the HV on the copier.
    I am stumped. Please advise. Thank you,
  • ZOOTECH
    Senior member of CRS
    • 3383
    Yes, it could be a bias trouble, but it might be that the LSU is firing all the time, which would fill up the waste toner quickly and give you black copies. A DV adjusting to 169 is pretty high, 139 is closer to normal. How is the DV bias, and have you cleaned the toner sensor (it can be caked with toner causing a misread)?
    Let us know what fixes it, thank you.
    • mtech
      • Mar 2007
      • 307
      Check your drum ground and main charge. Is the copy actually all black or is there a faint image in the back ground? Main charge could be shorting.
        • 22865
        I'm leaning towards primary charge loss. Whether you've got a short somewhere, or an open primary charge contact, or the HVT is not giving you any primary charge, I don't know....
        .....this is all presuming that there is some indistinct image in your black pages.
        If there is no image, then the laser is more likely. I've got to say, though, that its very rare to have a bad laser driver board. Usually only the polygon mirror motor fails and gives a code. =^..^=
        • MHeon71
          • Oct 2008
          • 485
          There is a bulletin on Sharps web site for this problem. Try changing the main charge. They changed the MC unit. The new part # is CHLDZ0035RS57. The last digit has changed from a 3 to a 7 and it is the same one that is used in the AR-M317. They removed teeth from the saw tooth on both ends where the screen grid stops to prevent leaking. I had a customer that had black copies once a month changed th MC and problem has not come back since September.
          • mlbcopiers
            • Oct 2007
            • 34
            I changed the main charge unit, and the problem went away.
            Thank you for the information.
            I also ordered the new charge unit.
