SF 2027 line on copy
  • mlbcopiers
    • Oct 2007
    • 34
    I have a Sharp SF 2027. I did a pm about six months ago, replaced drum and developer. The copier has faint grey lines on the copy. I cleaned everything, and adjusted the exposure. The lines seem to go away, more so after running a number of copies. The customer says that the lines are most apparent when he first uses the copier in the day.
    Could there be some sort of short causing the grey back ground. There was alot of toner in the lower dv unit, just under the mag roller. I don't think the copier is overtoned. I did order new dv today. I feel like the drum is not holding the charge properly.
    Any help will be greatly appreciated.
    I know it is an old copier. The machine runs fairly well beside this problem.
    Thanks,
  • NCArt
    Mountain Tech
    • May 2008
    • 81
    Look at your charge corona and grid. It sounds like the unit is dirty and arcing. Clean the grid with alcohol and restring the corona.
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1867
      Art, the 2027 uses a sawtooth for the main charge & wires for transfer & separation. I'd clean the main charge & replace the trans/sep wires, although that shouldn't give you lines. It usually gave void lines on the analogs.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
        • 22997
        tmaged is right on that. Charge sawtooth won't cause lines at the beginning of a copy run, but severe overtoning can. When you have the lower lip of the developing unit filling up with toner you can be sure that it is overtoning.
        That new developing unit will not have any developer, so be sure to order some SF-222ND1.
        • NCArt
          Mountain Tech
          • May 2008
          • 81
          Gentleman, I may have been wrong about the charge using a wire, I have seen several times where a grid that has toner dust all over it cause arcing, esp when the charge begins. I had a SF 2035 do that at a customers office back in 2001.
          • vincent64
            • 382
            That old SF 2027 was a decent machine, but if them supplies were old, had been on a shelf a while, may be the prob, when you run DV cal, T.C 25-2, what were the numbers while it was running, should be at least above 60 or so, old DV will run low on the numbers, making it over tone after a while.
            When cleaning the grid, use a water based cleaner first, we use simple green, then achol after to remove any soap residue from the grid, if the saw tooth is pretty new, some foam packing will clean it ok, I use some fine sandpaper, 320 grit wet/dry paper, works great, or the brown scotchbrite pad, paper is easier to clean the sawtooth with though.
            One more thing, check the DV drive unit on the back side of the machine, that orange gear gets gummed up, may slow things down just enough, have seen them cause L4 codes also.
