Sharp ARM 207 maintenance
  • joegarz
    Hi, i work mainly on Ricoh. i need to know if is it there a problem with just reseting maintenance or not. Asking for maintenance at 50k. Thanks
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1867
    The only problem on these occurs if the drum gets worn down to bare in any spot. You'll get light streaks from front to rear from voltage leaking. If the drum looks good, you should be fine.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
      • 22996
      A basic PM is drum, blade, developer, and fuser felt.
      For service mode: #, interrupt, 0, interrupt
      Sim 25-2 for developer stir
      Sim 24-7 to reset drum light
      Sim 42-1 to reset developer count
      Sim 20-1 to reset maintenance light
      Quick & easy. =^..^=
