Mirroring images/characters MX6240 DSPF SCANNER
  • rayjeek
    • Jun 2010
    • 239
    [CQ] Mirroring images/characters MX6240 DSPF SCANNER
    Hi All,
    I have MX6240 that produces mirror image/characters when making copy via platen glass and ADF, print is fine. Cleaned optics and update firmware but not difference. Have attached sample, add and platen glass copy. Please expand image to see mirroring effect.
  • rayjeek
    • Jun 2010
    • 239
    Re: Mirroring images/characters MX6240 DSPF SCANNER
    Sorry for not attaching the sample, now attached. However, the issue has been narrowed to the CCD as the duplex copy via the DSPF has the 2nd side ok, no mirroring.
      that looks like ghosting... images you posted I can't expand enough.. PDFs work better for uploading
      what are the lifes on Service parts.
      have you looked in SM for "ghosting"?
      • rayjeek
        • Jun 2010
        • 239
        Hi Phil,
        All SM parts are ok. The problem is with the scanner as prints are fine. Also with double-sided copies through the single pass feeder, the 2nd side comes out good with no ghosting/double image.
        • ZOOTECH
          Senior member of CRS
          • 3375
          Check that the mirrors are not 'skewed'.
          • rayjeek
            • Jun 2010
            • 239
            Thanks Zootech. Will check it
              • 23003
              Did you happen to remove any of those mirrors? Remember that copiers use only front surface mirrors. If you install the reflective surface at the back of the mirror you will get both a reflective and a refractive image slightly offset. =^..^=
              • rayjeek
                • Jun 2010
                • 239
                No work done on the mirror but as you mentioned will have a look at the mirrors
                • rayjeek
                  • Jun 2010
                  • 239
                  Update.. The CCD replaced to resolve problem.
                  Thanks.
