MX2700N
  • tcypy1961
    • 773
    [CQ] MX2700N
    I usually handle just mechanical issues with this copier; not sure if this is one. Customer said the copier was leaving streaks then upon arrival called it ghosting which is what I saw(I call offsetting). Matching the ghost image with actual image it looks like a drum would be the cause. However I see no evidence as I would expect on any of the drums. The problem is more pronounced in black than full color but still there. I see nothing on fuser rollers which were just replaced or on transfer belt. Any help GREATLY APPRECIATED!!!
    • 22997
    Re: MX2700N
    Samples? =^..^=
    • Toner Boy
      • Aug 2007
      • 357
      Re: MX2700N
      paper type, weight, improper setting for print media ?
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Re: MX2700N
        Samples? =^..^=
        +1
        Regards Mark
        • copiertec
          • Jan 2016
          • 2191
          Re: MX2700N
          I hate to ask the obvious...are the pressure tabs in the fuser engaged or disengaged? Usually happens after customer removes a jam, they engage the pressure tabs to separate the fuser rollers, then forget to place them back into position.
