Customer is complaining of tray 1 jams, there were 20 tray 1 jams in 300 copies. When I get there, I ran over 50 copies without 1 jam. There is also a thumping noise. Sounds like it is right before or after the sheet is picked up from tray 1. No other tray has this thumping noise. Any suggestions before I get a clutch pack.
ARM350N - Tray 1 jams and thumping noise.
Tags: arm350n, bushings, dev, feed rollers, fusing unit, jams, lef, lift motor, noise, pressure roller, separation roller, shee, sound, spare parts, tray
If it's strictly when feeding from tray 1 I would check the tray height sensor, the lift motor, and subsequent interaction of the two. Also, the separation torque limiter sometimes makes noise...sigpic -
Guys the first thing I would check on this is the resist roller assy, tray 1 feeds at a different angle going into the resist roller. if the resist roller has a flat spot, it will cause a thunping sound and jamming issues from tray 1 but it wont be as bad from the other trays. Hopes this helps.Comment
OMD-227
Totally agree with mmru4real. The first thing you should look for with a thumping noise & multiple jams (especially in tray1), would be a worn set of PF rollers. There is a big chance of a flat-spot on the separation roller.
Easy one.Comment
Hi Guys
last count I looked after about 137 machines of this model 350/450 355/455, buddy is right the problem and thumping noise is 95% of the time caused by the PF rollers. I would replace paper feed rollers, also the torque limiter, there has been an upgrade to the part. Also I have seen this jamming problem from tray 1 a few times because the registration rollers were turning stiff, I think it has to do with the angle of the paper entry. a few drops of lube where the shafts turn on the bushings will clear this up. I usually do this during PM calls also. It will save service calls.Comment
I agree with the previous posters: Get some tires installed. There is another possibility (much less likely).
AR-M355N
Misfeeds (jam code TRAY1). After rollers are changed jam code changes (jam code PPD_ST1), after running pre-perforated cardstock & repeated jamming. Tray #1 lower separation guide is broken at its front swivel. Remove the print engine. Remove these units: drum, developing, cleaning, registration. Flip engine upside down. Remove left cassette rail to install the tray #1 lower separation guide (PGIDM1892FCZZ).
=^..^=If you'd like a serious answer to your request:
Almost the same as at my few copiers ( every copier has more than 2.000.000 copies ) Trumping noise from all trays but without any jams -alredy replaced exit unit,reg. unit,drum and dev. unit,main drive assy,and still nothing but copiers works without any problems. I am very interested in this NOISE!Comment
Fuser replaced? flat spots on pressure roller?sigpicComment
Only problem with that is he would have jamming from all trays and not just tray 1 if it was the fusing unit. My guess is still registration unit, and especially if the gear on that unit is missing teath or it has a flat spot. Becuase Tray 1 feeds at a different angle directly into that unit compared to the other trays!Comment
