MX-3110N Faded Prints, Copies Good
  • mioduz
    • Oct 2020
    • 34
    Re: MX-3110N Faded Prints, Copies Good
    Originally posted by danny464
    can you upload the file you are printing?
    To be clear all color prints are severly faded
    But this is the file I've been working with
    And before anyone asks I'm not using the paper in this picture if was just something bright I had laying around
      what is the PAPER type you have designated in the tray and the print driver?
      high gloss paper needs a thick1 setting for the toner to bong to the page properly
      • mioduz
        • Oct 2020
        • 34
        Just cheap copy paper. What ever staples had on sale last. Tray setting to plain
          So the pic ISN'T the paper being used?
          • mioduz
            • Oct 2020
            • 34
            #20
            That is correct
            • copiertec
              • Jan 2016
              • 2211
              #21
              as mentioned above, restore factory defaults, then go from there.
              • mioduz
                • Oct 2020
                • 34
                #22
                I haven't been able to locate a "reset to default" option in the web page setup. Can you provide any.futhor guidance
                • copiertec
                  • Jan 2016
                  • 2211
                  #23
                  Access it from the control panel of the mfp and follow the steps provided.
                    he's an end user .. this might cause more problems for us.
                    • mioduz
                      • Oct 2020
                      • 34
                      #25
                      I used option:
                      67-17 Printer reset The set data related to the printer are initialized. (Including the NIC setting.)
                      to reset the printer. No change when printing a JPG from thumbdrive
                        I used option:
                        have you tried printing a PDF sometimes JPG's are screwy
                        • miller01123@gmail.com
                          • Jun 2019
                          • 55
                          #27
                          On the op-panel of the machine you should see a Settings button. That should get you started. The password should be "admin".
                          • mioduz
                            • Oct 2020
                            • 34
                            #28
                            Since the begining of this project I have been using a pdf printer test file as well. cmyk shaded scales etc etc. Same faded result
                            • copiertec
                              • Jan 2016
                              • 2211
                              #29
                              It's a harmless reset, just puts the mfp back to factory, it's not accessed by sim codes.
                              • mioduz
                                • Oct 2020
                                • 34
                                #30
                                I was not able to find this factory reset that you speak of
