Sharp MXB402 - Paper Jam/New Fuser Unit
  • lifestyles
    • Nov 2020
    • 4
    Hi,
    So our printer have been having a paper jamming issues. Notice that the lower pressure roller was damaged so we replaced the whole fuser unit with an OEM one. After installing the new fuser, it would jam right before the fuser.
    • 22703
    Re: Sharp MXB402 - Paper Jam/New Fuser Unit
    Are you sure that "jamming" isn't really an "L4-16" error code?
    I seem to recall that if the fuser is not changed quite correctly the pressure release cam will break on the new unit.
      • 22808
      Originally posted by lifestyles
      Hi,
      what is the jam code?
      have you cleaned the sensors?
      what is the count on PM parts?
      • lifestyles
        • Nov 2020
        • 4
        H5-01
        POD1
        • mojorolla
          The Wolf
          • 2550
          H5-01 will need to be reset via SIM mode. With POD1, check the sensor actuator, spring and the actual sensor in SIM mode to ensure it is going H /L.
          • spanky
            • Sep 2012
            • 468
            Is there any print on the paper that jams?
            You could have a cleaning blade flip on the transfer belt unit.
            • lifestyles
              • Nov 2020
              • 4
              yes there is
              • lifestyles
                • Nov 2020
                • 4
                H501 has been resetted SIM mode 14. Do you know what program number for POD1 would be?
                • OlliK1969
                  • Nov 2016
                  • 287
                  Hi
                  Are the levers for the lower press roller in the correct position?
                  • danceswrabbit
                    • Dec 2013
                    • 63
                    gear that drives fusing unit?
                    • Dcopyman
                      • Apr 2020
                      • 34
                      Check sensor for registration unit..... Behind PS unit... what jam code is it showing?
