Sharp mx-m453u
  • ali.nadri
    • Feb 2021
    • 27
    [Error Code] Sharp mx-m453u
    Hello
    Sharp mx-m453u had no problem.
    was healthy.
    I selected the option 88-01 in the settings.
    "all memory clear"
    Now it gives the following message:
    Improper cartridge(code : F2-70)
    I replaced the cartridge chipset.
    I do not have access to the Sharp site.
    Do you think the firmware update on the device will work?
    How can I fix this problem?
    What is your suggestion?
    Thanks...
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: Sharp mx-m453u
    This is interesting. There's either a soft switch for "allow generic toners" or maybe the machines "country code" But I don't know either of those things, especially on an older machine like that. I'd see if an OEM toner works
    • ali.nadri
      • Feb 2021
      • 27
      Re: Sharp mx-m453u
      I replaced the cartridge.
      But it still gives the following code:
      "F2-70"
      • mansart
        • 852
        Re: Sharp mx-m453u
        Set destination code with
        26-6
        • ali.nadri
          • Feb 2021
          • 27
          Re: Sharp mx-m453u
          Not resolved.
          • ali.nadri
            • Feb 2021
            • 27
            Re: Sharp mx-m453u
            help me!
            Anyone an idea ??
            • spanky
              • Sep 2012
              • 468
              Re: Sharp mx-m453u
              He has sent me a private message asking for firmware.
              I don't have a drop box to put it in and the file is too large to email.
              Can anyone help him with this.
              He is in Iran and I am not sure the North American firmware would work for him.
              • ali.nadri
                • Feb 2021
                • 27
                Re: Sharp mx-m453u
                I updated the firmware with the file sent by my friends, but it still gives an "F2-70" error.
                • spanky
                  • Sep 2012
                  • 468
                  Re: Sharp mx-m453u
                  Are you using Sharp OEM toner or a third party toner?
                  • ali.nadri
                    • Feb 2021
                    • 27
                    Re: Sharp mx-m453u
                    3.JPGyes.
                    I use Sharp OEM toner.
                    • ali.nadri
                      • Feb 2021
                      • 27
                      Re: Sharp mx-m453u
                      • mloudy
                        • Oct 2015
                        • 788
                        Re: Sharp mx-m453u
                        A MX-500GT is listed for Europe/Australia/New Zealand. Is Lordegan in Iran? The service manual lists other supplies for the Middle East but I'm not certain which toner is for that area.
                        SMEF/Taiwan/Africa/Israel/Philippines = MX-500FT
                        SESC = MX-500CT
                        MPE = MX-500BT
                        Asia/SRH = MX-500AT
                        Is that blue crum chip OEM Sharp? Ours are black and have the Sharp logo melted into them. If the chip is generic and all you are doing is putting on new generic crum chips then that might be the problem.
                        • ali.nadri
                          • Feb 2021
                          • 27
                          Re: Sharp mx-m453u
                          Before I entered the code 88-01, the device worked with the same chipsets!
                          Now gives the code F2-70?
                          I tried several different chipsets but it didn't work?
                          • mloudy
                            • Oct 2015
                            • 788
                            Re: Sharp mx-m453u
                            I am not sure what this is:
                            "option 88-01 in the settings. "all memory clear"
                            I have worked on the model since it came out and I am not familiar with an 88-01 all memory clear. Is this one of those hidden sims that shouldn't be used?
                            As I do not know what memory has been cleared exactly I can't be sure what to tell you.
                            Again, are these chipsets OEM Sharp? Are you simply changing chipsets and not installing a new OEM Sharp toner? If you can answer these two question it would give us a better idea of how to figure out the problem.
                            • mojorolla
                              The Wolf
                              • 2627
                              Re: Sharp mx-m453u
                              This is a Sharp that still has "super secret service mode". I think SIM 88 is only available there. You can do all kinds of cool (and dangerous) things in that level.
