Sharp mx-m453u
  • ali.nadri
    • Feb 2021
    • 27
    #31
    Re: Sharp mx-m453u
    Attention:
    1. Before entering the code (88-01), the device was completely safe. I entered this code out of curiosity. I did not know the consequences.
    2- My country is Iran.
    3- I tried all the country codes with (26-06). Not solved!
    4- I tested several types of chips. Not solved!
    5. I replaced the cartridge. Not solved!
    6- I updated the firmware. Not solved!
    • mloudy
      • Oct 2015
      • 789
      #32
      Re: Sharp mx-m453u
      I am willing to invest time in a solution for you now that you have provided more information.
      I have several MX-M453N copiers so I can preform a 88-01 on one of them Monday. I will clone it first and then once I have cleared its memory I will see if I can restore it to working condition with the clone. I don't have much hope that it will work but I will try.
      Send me a private message with the key sequence to enter the special sim codes. It has been years since I have done it and can't remember the sequence. It is best that the sequence isn't posted here and made available to the public.
      • romang
        • Aug 2011
        • 72
        #33
        Re: Sharp mx-m453u
        Ok, after checking the manual, I would copy all the settings from a working machine specifically all sims in 26 . I dont think a clone will work because that only copies user/admin settings not sim settings.
        Also, the settings will still have to match his toner cartridge. So if you enter settings for a USA machine the toner will need to be as well. Thats all the advice i can give other than that its a brick.
        • efe311
          • Oct 2008
          • 114
          #34
          Re: Sharp mx-m453u
          Originally posted by ali.nadri
          I updated the firmware with the file sent by my friends, but it still gives an "F2-70" error.
          Please please i need this firmware please
          My dropbox acc.
          EFE311@GMAIL.COM
          • efe311
            • Oct 2008
            • 114
            #35
            Re: Sharp mx-m453u
            Attention:
            [ATTACH=CONFIG]48364[/ATTACH]
            Please can you send me the firmware file please
            My dropbox acc.
            EFE311@GMAIL.COM
            • romang
              • Aug 2011
              • 72
              #36
              Re: Sharp mx-m453u
              Firmware isnt going to fix it.
              • efe311
                • Oct 2008
                • 114
                #37
                Re: Sharp mx-m453u
                Can any one send me th firmware
                For MX 453
                MY DROPBOX ACC IS
                EFE311@GMAIL.COM
                • romang
                  • Aug 2011
                  • 72
                  #38
                  Re: Sharp mx-m453u
                  efe311 quit trying to hijack threads I see you posted on other threads asking for firmware . Maybe if you contributed someone might help you.
                  • ali.nadri
                    • Feb 2021
                    • 27
                    #39
                    Re: Sharp mx-m453u
                    Warning:
                    "Do not use this code (88-01) on your device for curiosity !!!"
                    • ali.nadri
                      • Feb 2021
                      • 27
                      #40
                      Re: Sharp mx-m453u
                      Thank you very much for following up.
                      My suggestion is: do not do this.
                      Your device may be corrupted.
                      • mloudy
                        • Oct 2015
                        • 789
                        #41
                        Re: Sharp mx-m453u
                        I know it will likely make my machine useless but I think there are at least 10 of these in the warehouse and all we use them for are parts.
                        We don't need them to be functional so I have no problem executing 88-01 on one of them to try and see if it can be restored to working condition.
                        • mloudy
                          • Oct 2015
                          • 789
                          #42
                          Re: Sharp mx-m453u
                          Executed an 88-01 and the copier rebooted fully functional.
                          Jams, errors and counters were all reset to 0 except TONER MOTOR K and TONER TURN K. I assume that data is held on the toner crum chip.
                          We set MFP soft switch 32 to 01000000 and after the 88-01 it was at the default of 00000000. I think all other soft switches probably returned to their default settings.
                          I would assume a full PM would need to be preformed to get process control back. Even at that I think there might be some weirdness experienced if the machine was put back into use.
                          • ali.nadri
                            • Feb 2021
                            • 27
                            #43
                            Re:Thank you
                            [ATTACH=CONFIG]48373[/ATTACH][ATTACH=CONFIG]48374[/ATTACH]
                            • ali.nadri
                              • Feb 2021
                              • 27
                              #44
                              Re: F2-70
                              I do not know what changes have been made in the device after entering the code 88-01!
                              Still gives error (F2-70).
                              The question is:
                              Is there a solution for the Sharp device not to check the cartridge?
                              • ali.nadri
                                • Feb 2021
                                • 27
                                #45
                                Re: Sharp mx-m453u
                                The problem may be solved with the following three files:
                                Files must be downloaded from a healthy device.
                                The first file with code 56:
                                MX-M453U_9501731000_NV_ALL_20210223_1155.dat
                                The second file with code 92:
                                NVRAM.DAT
                                The Third file with clone settings:
                                MX-M453U_9501731000_B_20070320_230818.bin
                                Does anyone have a healthy Sharp (MX-M453U) device?
                                Just this model.
                                If you have, please send me these files.
                                Thankful.
