Sharp mx-m453u
  • mloudy
    • Oct 2015
    • 789
    #16
    Re: Sharp mx-m453u
    The only thing I ever used the secret sims for were to correct meters that techs accidentally zeroed out on the Cougar series. First you had to find the sim and then convert hex to dec or the other way around. If you never had to do it then you have 6 extra months you will live.
    ali may have cleared something that has caused this issue. Process Control, toner level, toner counter... IF he could get a 22-6 he may find zeros where there should never be zeroes.
    • ali.nadri
      • Feb 2021
      • 27
      #17
      Re: Sharp mx-m453u
      Attention:
      "Do not use this code (88-01) on your device for curiosity !!!"
      • ali.nadri
        • Feb 2021
        • 27
        #18
        Re: Sharp mx-m453u
        The hardware of this device is healthy.
        The code (88-01) changed all device settings to zero.
        Now I do not know which zero should change.
        Which code should I change to identify the cartridge?
        • mojorolla
          The Wolf
          • 2627
          #19
          Re: Sharp mx-m453u
          That's SIM 55, soft switches. Those are not counters. Whatever switches and bits you changed needs to be changed back. These are not listed in any manual.
          • mloudy
            • Oct 2015
            • 789
            #20
            Re: Sharp mx-m453u
            I will see if I can find out what those soft switches are for.
            If would be really really helpful if you would answer questions. If you keep refusing to answer questions and keep posting Help me Help me, you will find that people will start ignoring you.
            • ali.nadri
              • Feb 2021
              • 27
              #21
              Re: Sharp mx-m453u
              "According to previous submitted photos"
              I know toners, chips and cartridges are healthy.
              But I'm not sure if the cartridge and chip are OEM Sharp!
              • mloudy
                • Oct 2015
                • 789
                #22
                Re: Sharp mx-m453u
                You may have made the machine inoperable for good.
                I printed out a 22-6 from a MX-M453N and these are the only soft switches that are not at all zeroes, Engine & MFP. Setting your machine to match may do nothing to restore it as it is in a different region and soft switches may not match.
                MFP SOFT SWITCH
                2 11001000
                25 00110000
                32 01000000
                ENGINE SOFT SWITCH
                2 01000000
                It also may be as simple as installing a new toner OEM toner as (I think) you just replaced the crum chip.
                • ali.nadri
                  • Feb 2021
                  • 27
                  #23
                  Re: Sharp mx-m453u
                  MFP SOFT SWITCH
                  2 11001000
                  25 00110000
                  32 01000000
                  ENGINE SOFT SWITCH
                  2 01000000
                  Thanks for your answers
                  Changing these codes did not solve the problem.
                  Is there a software switch for "Allow public toners"?
                  • mansart
                    • 852
                    #24
                    Re: Sharp mx-m453u
                    What about a clone???
                    It's already a brick....
                    If you plug machine into a network, can you access the web interface?
                    • ali.nadri
                      • Feb 2021
                      • 27
                      #25
                      Re: Sharp mx-m453u
                      Yes, I have access to device settings over the network.
                      Do you have a solution?
                      • mansart
                        • 852
                        #26
                        Re: Sharp mx-m453u
                        Do you have access to another machine of the same line?
                        M283
                        M363
                        M453
                        M503
                        You could try to clone settings from one to the other.
                        • ali.nadri
                          • Feb 2021
                          • 27
                          #27
                          Re: Sharp mx-m453u
                          M283
                          M363
                          M453
                          M503
                          Thank you very much for your answer.
                          No, unfortunately I do not have access to another machine.
                          If you have access to these devices, please send me the file(Device Cloning).
                          • ali.nadri
                            • Feb 2021
                            • 27
                            #28
                            Re: Sharp mx-m453u
                            Originally posted by JR2ALTA
                            This is interesting. There's either a soft switch for "allow generic toners" or maybe the machines "country code" But I don't know either of those things, especially on an older machine like that. I'd see if an OEM toner works
                            Thank you for your answer
                            • romang
                              • Aug 2011
                              • 72
                              #29
                              • mloudy
                                • Oct 2015
                                • 789
                                #30
                                Re: Sharp mx-m453u
                                So the sticker on his toner is a MX-500GT, Europe/Australia/New Zealand and he never did answer my question of if he was in Iran. Who knows which crum chip he is using.
                                My next questions to you ali are. Have you ever used this 88-01 before? I'm confused because you said it was working fine.
                                Did you think the 88-01 would just reset the machine back to its "out of the box' condition? If you have cleared everything as romang states then your problems are going to be far greater then getting a toner to work.
