Sharp mx-m453u
  • ali.nadri
    • Feb 2021
    • 27
    #46
    help me:
    friends:
    Does anyone have a healthy Sharp (MX-M453U) device?
    • romang
      • Aug 2011
      • 72
      #47
      Re: Sharp mx-m453u
      What files are those ? From what sim codes ?
      • TechGeek
        • 158
        #48
        Re: Sharp mx-m453u
        First off you should have never went into the TC 88 when you have a properly working MFP.
        Was a 22-06 printed off before the 88-01 was executed?? If so print out the the 22-06 and compare the soft switch settings and make necessary changes to help restore the MFP.
        I also think it has something to do with the country codes and device model not being correct.
        Just curious will the MFP boot up as normal without the toners installed?
        • ali.nadri
          • Feb 2021
          • 27
          #49
          Re: Sharp mx-m453u
          Thanks for your follow up.
          These files are backup.
          Taken with codes 56 and 92 in Sharp device.
          Via USB port and network port.
          • ali.nadri
            • Feb 2021
            • 27
            #50
            Re: Sharp mx-m453u
            No. I did not print.
            Do you have a solution?
            • ali.nadri
              • Feb 2021
              • 27
              #51
              Disable cartridge checking
              Is there a way to disable check the cartridge in Sharp?
              • mansart
                • 852
                #52
                Re: Sharp mx-m453u
                I believe SIM 7. You can disable certain items that are needed for READY condition
                This is used for testing not a fix
                • ali.nadri
                  • Feb 2021
                  • 27
                  #53
                  device reboots
                  thanks for your answer.
                  Using this method, the device works temporarily.
                  When the device reboots or standsby,
                  Gives the message again (F2-70)?
                  • ali.nadri
                    • Feb 2021
                    • 27
                    #54
                    mx-m453u
                    • james62525
                      • Aug 2017
                      • 7
                      #55
                      Re: Sharp mx-m453u
                      how do you into the option 88-1?
                      can you teach me?
                      thanks
                      • james62525
                        • Aug 2017
                        • 7
                        #56
                        Re: Sharp mx-m453u
                        Originally posted by ali.nadri
                        Hello
                        Sharp mx-m453u had no problem.
                        was healthy.
                        I selected the option 88-01 in the settings.
                        "all memory clear"
                        Now it gives the following message:
                        Improper cartridge(code : F2-70)
                        I replaced the cartridge chipset.
                        I do not have access to the Sharp site.
                        Do you think the firmware update on the device will work?
                        How can I fix this problem?
                        What is your suggestion?
                        Thanks...
                        can you teach me?
                        very thanks
