Sharp MX 2700
  • copymon
    • 39
    Sharp MX 2700
    Looking for the set-up procedure for the Sharp MX 2700 color copier.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1887
    It's a pretty advanced set up if you're not a tech. You'd be better off paying to have it done.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
      • 23008
      I'd have to agree. The color calibration is not for amateurs. =^..^=
      • copymon
        • 39
        I have been a copier tech since 1983, any info for the set up would be great, Thanks.
        • Tommyc
          • May 2008
          • 22
          Hi there guys,
          Looking for info on error code f266 on Sharp MX2700....
          • bilyahn
            • Dec 2006
            • 1470
            Originally posted by Tommyc
            Hi there guys,
            Magenta toner supply error. Here are some things to look at from the SM. There have been some issues with the toner pipe clogging but I haven't come across this yet.
            Good luck.
            Bil
            Trouble content Toner end with the remaining quantity of 50% or more.
            The toner supply time exceeds 3 times as much as
            the specified time.
            Section PCU
            Case 1 Cause Toner motor section connector harness trouble
            Check
            and
            remedy
            Check the connector connection of the toner motor
            section.
            Check the connector harness (TM) connection to the
            main PWB.
            Case 2 Cause Toner motor and toner density sensor trouble
            Check
            and
            remedy
            Check the toner density sensor output. (SIM25-1)
            Check that the toner transport pipe is not clogged
            between the toner cartridge and the developing unit.
            Replace the toner cartridge (CRUM) if necessary.
            If replacement of the toner cartridge (CRUM) does not
            clear the trouble, check the developing unit.
            • costd
              • Jan 2008
              • 409
              Installation instructions come with the machine - and are also available online from Sharp. Rough concept: unbox and remove all tape. Install optional equipment. Install developer. Install Toner BUT DO NOT CLOSE FRONT DOOR. Power on. Developer simulation. Close door. Most often the colors and skew will be ok (we calibrate anyway).
              As I said, a rough concept. If you do not have access to Sharp, ask whomever your boss purchased the unit from to provide you with the service manual.
              Perhaps he should have said "if your not a Sharp tech" as commercial grade units are not "plug and play".
              • JustManuals
                • Jan 2006
                • 9838
                This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
                Paul@justmanuals.com
