bad Magenta fill on BP-70C55
  • Steve Tech
    • May 2024
    • 35
    #16
    Have the exact same issue with a BP- 50C65, so far had 3 bags of dev and a new dev unit still the same, have also checked the erase lamps and they're all in the correct position
    Just fitted a replacement MC PWB to see if that helps, trouble is it will be a couple of months for the issue to show again.
    • Massimo
      • Feb 2023
      • 22
      #17
      Che sia CBOX-0233FC32 Middle toner hopper unit che non riesce a fornire di toner il dv?
      • Steve Tech
        • May 2024
        • 35
        #18
        Are you talking about the technical report for a gear becoming dislodged, if so I've had that off and all looks good. Anyhow, that would surely result in a F code I would have thought
        • Steve Tech
          • May 2024
          • 35
          #19
          Originally posted by driving lots of miles
          Thanks, that was the next thought I was tossing around but wanted some input as it is way early for developer.
          The dev on these doesn't actually have a specified life, its supposed to last the life of the machine
