Sharp mx4141 firmware / scan to google drive
  • Forzagp
    • Feb 2019
    • 13
    Hi please let me know if you have the latest firmware for this unit and if there’s a way to set it up for scan to google drive or workspace. The sharp OSA button just goes to a white screen. Thanks
  • Doug.P
    • Aug 2015
    • 53
    Does your machine have an OSA MX-AMX2 APPLICATION COMMUNICATION MODULE installed? I have attached a Bulletin from a newer Machine which explains the requirements for OSA TT-022516_1.pdf
    • Forzagp
      • Feb 2019
      • 13
      Thanks for the reply. It doesn't look like it - here's the config page Device Configuration
      Paper Feeding Options Stand/MPD&2000 Sheet Paper Drawer
      Paper Exit Options Saddle Stitch Finisher
      Punch Module
      Memory Size Copier Memory Base Memory 1024 MB
      Optional Memory 0 MB
      Total Memory 1024 MB
      Printer Memory Base Memory 3072 MB
      Total Memory 3072 MB
      Hard Disk Drive 305.2 GB
      Options Fax Module
      Enhanced Compression Kit
      Is it possible to scan to google drive from this machine or to install apps? I don't see a way that matches the more recent versions of the machine.
      Do you think a firmware upgrade would add these features or make the setup easier. It won't let me browse for folders for scan to folder.
      • Hart
        • Feb 2024
        • 399
        Nope not compatible at all.
        • Doug.P
          • Aug 2015
          • 53
          No firmware will not solve the issue it requires the option MX-AMX2 APPLICATION COMMUNICATION MODULE which has to purchased.
          • ihatefinishers13
            Senior MFP Technician
            • Feb 2020
            • 693
            Your best option is to scan to a folder, and point it to the Google Drive folder residing on a PC. If it's just going to one folder, it's not a big deal, but otherwise you'd need a newer machine.
            • boutn
              • Jun 2016
              • 547
              The MX4141 should have the mx-amx2 as a standard if i'm not mistaken...
