How to disable auto-cropping scan on a BP-70C45?
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 695
    Originally posted by PacMusee
    You are then proving the default scan isn't actually full size on the 70C series, as the corners are cropped.
    Apologies, I should have included a photo of the original, so you can compare.
    • ihatefinishers13
      • Feb 2020
      • 695
      Here's something from an old 5070v, just throwing it in there so you can see as well. I can't tell if there is a problem, I'm just putting more samples out there for others to also deliberate on.
      • PacMusee
        • Aug 2016
        • 55
        No, it's ok. It was clear you use my same template for corners, and it showed as cropped.
        • ihatefinishers13
          • Feb 2020
          • 695
          #19
          But what about the 5070v sample? It shows cropping as well, but different sides. Idk what to make of it
          • PacMusee
            • Aug 2016
            • 55
            #20
            Thanks.
            Weirdly, the corners near the starting point of the glass are ok, while the exterior corners were cropped... That doesn't go in the same direction of either issue!
            • ihatefinishers13
              • Feb 2020
              • 695
              #21
              Thanks.
              At this point, every machine is different, every one of them need aligned and such when a dealer gets them... You'd think by now Sharp would have it down to a perfect science.... But they're not getting a lot of things right, lately.
              • PacMusee
                • Aug 2016
                • 55
                #22
                Good news!
                Calibration was done on every copier here, and the parameters were simply set to 0 to obtain the full scan. No more cropping!
