MX-601 Fusers
  • ron67601
    • May 2025
    MX-601 Fusers
    I'm having to replace these half way through their life expectancy. Some will wrap paper around lower roller ans others will just jam 2 or 3 sheets under the separator bar. Has anyone tried using 607 fusing belt and lower rollers in a 601 fuser? Just wondering because those seem to last a little longer. Or messing with the temperature? Any feedback would be appreciated. Thanks Ron
  • bilyahn
    • Dec 2006
    • 1468
    Re: MX-601 Fusers
    I use the 602 belt for these. Never have used the 601 belt. If you don't know this already be sure to bring the copier up with out the fuser installed. It resets some settings in the machine, then power down and install the fuser. You will get better yield on your fusers.
    Good luck
    Bil
    • ron67601
      Re: MX-601 Fusers
      Good luck
      Bil
      Another question - Have anyone seen cleaner roller units for these? I was searching one day on google and ran across some sites overseas that use some. I inserted that part number in TechData and it was accepted. Also do you think I could use a MX-608FB in a pinch for a 601 fuser unit? Those seem to be on backorder all the time. I sure hope the BP series fusers are much better because the 601's stink. Thanks Ron
      • ron67601
        Re: MX-601 Fusers
        I use the 602 belt for these. Never have used the 601 belt. If you don't know this already be sure to bring the copier up with out the fuser installed. It resets some settings in the machine, then power down and install the fuser. You will get better yield on your fusers.<br>
        <br>
        Good luck<br>
        <br>
        Bil
        <br>
        <br><br>Another question - Have anyone seen cleaner roller units for these? I was searching one day on google and ran across some sites overseas that use some. I inserted that part number in TechData and it was accepted. Also do you think I could use a MX-608FB in a pinch for a 601 fuser unit? Those seem to be on backorder all the time. I sure hope the BP series fusers are much better because the 601's stink. Thanks Ron
        • bilyahn
          • Dec 2006
          • 1468
          Re: MX-601 Fusers
          We used a 608 one time and it did not work very well. Not sure why because I use the 608 in the 70 series with no problems but in the 71 series they don't last or at least not in the unit we put it in.
          Good luck
          Bil
          • mloudy
            • Oct 2015
            • 771
            Re: MX-601 Fusers
            Throwing out the odd calls like a customer breaking something in the fuser or rebuilt units failing the next day here are the numbers from our machines.
            Average life 200,728
            Longest life 301,582
            Shortest life 64,397
            These numbers might be a little on the low side as our techs carrying rebuilt fusers with them. A call for a bad thermistor on a copier an hour away might get a compete fuser replacement.
            • boutn
              • Jun 2016
              • 537
              Re: MX-601 Fusers
              DUNT-9555DSZZ CL Roller Unit
              We're trying these where there is a lot of paperdust-buildup on the pressure roller...instead of swapping the fuser/pressure roller every 10 or 20K
              Our fusers don't get near the mileage of mloudy.
              • fireater
                Repair God? not quite
                • Apr 2006
                • 253
                Re: MX-601 Fusers
                <br>
                DUNT-9555DSZZ is cleaning unit
                they suck as well.
                i havent had much issues with paper wrapping lower roller? maybe try different brand of paper?
                I fix copiers ...Well Sorta
                • Alpanapa
                  • 20
                  Re: MX-601 Fusers
                  Common problem in some areas/countries. Change fuser temp with +10 degrees (SIM 43-1) on PLAIN PAP&WUP&RDY GR
                  See attached file for more information
                  Fuser temp setting.pdf
