Sharp AR 285 dots and lines
  • mrkabokieman
    • Jul 2025
    I have a sharp ar 285 and the copies are getting toner specs on them in random places, also when i turn paper to grip the 11 inch side it gets a line across the page
    Ive tryed running blank pages through and the specs are still there, also the specs still show up when running in simulation 64 mode
    • 23008
    The line is probably 1 of 2 choices. And the answer will depend on the answer to this question: Does the line on letter size images appear on your sim 64 test prints?
    If no, then it is an optical issue. That is, the mirrors, glass, or lens are dirty. If yes, it's probably the drum worn out.
    Do the specks have a recognizable pattern that repeats? If yes, you could have toner buildup on the upper fuser roller, or maybe label adhesive on the drum. If no, the developer may be overtoning, requiring a developer change.
    Lots of questions. Lots of possible answers. =^..^=
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1887
      More than likely the specs are toner droppings from the drum unit. Replace the 2 lower drum seals.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
