BP-70C series fuser
  • bigdaddyooo
    • Dec 2014
    • 211
    BP-70C series fuser
    Has anyone experienced 1 part of a print not fusing? It's on the rear side of a copy or print. I've torn the fuser apart and found nothing that I can see that would cause it.
    Are you the police? "No ma'am, were musicians"
  • driving lots of miles
    • Jun 2016
    • 398
    Re: BP-70C series fuser
    I would check the spring that hold the pressure roller in place and next check the that the pressure roller slides forward and back easily on the track.
    • ihatefinishers13
      Senior MFP Technician
      • Feb 2020
      • 689
      Would be easiest to swap the fuser so you'll know it's definitely at fault. Then you can try to visually compare both of them as well. On the 70/71 series' the fusing pressure springs could come off track when rebuilding the unit. But if it's doing it out of nowhere, I would think that adjusting the fuser temp in system settings from 16 to 23lb might make a difference. Otherwise maybe 43-1 could be of assistance.
