Cloning the SSD on BP's
  • Hart
    • Feb 2024
    • 378
    So it appears that I can't use SSD on BCR4 models (don't know about CR4) ...
    I've tried WD Blue, Crucial MX500, Kingston KC600, and an ADATA.
    The models will try to format them for almost a minute then boot with E7-03, same experience in 62-01, ERROR after 20-30 seconds.
    HDD is okay.
    • ihatefinishers13
      Senior MFP Technician
      • Feb 2020
      • 680
      HDD is okay.
      Is this after copying data from a known good SSD? And also was it B/M keyed? We tried with an M key, but it didn't work. We don't have any B/M keyed drives or we'd try that.
      • Hart
        • Feb 2024
        • 378
        ? It's a 2.5 SATA SSD, the key is only for M.2 connector (CR5 models).
        The copier will format a new drive at first boot if it's brand new, or throw a U6 error and you can format it with 62-01.
        • ihatefinishers13
          • Feb 2020
          • 680
          #19
          Sorry, thought you meant the BP series. What is a BCR4 model? Haven't heard that reference before.
          • Hart
            • Feb 2024
            • 378
            #20
            Monochrome CR4, M2630 M3050 M3070 ... M6050 M6070
            • ihatefinishers13
              • Feb 2020
              • 680
              #21
              Ahhh okay, would have never guessed that. We haven't had a monochrome hard drive fail, but we've put HDDs in the color 70 series no problem, but I don't think we've tried an SSD. We've put SSD's in the 71 series no problem, so long as we put the copied files on it first.
              • Squiggy
                • Jan 2020
                • 39
                #22
                We've been using transcend with a AVIO Duplicator on both color and B/W and so far no issues.
                • lky1978
                  • Mar 2009
                  • 483
                  #23
                  HI, can give me transcend ssd model which support cr4 b/w model
                  • Squiggy
                    • Jan 2020
                    • 39
                    #24
                    This What We Have Been Using
                    • ihatefinishers13
                      • Feb 2020
                      • 680
                      #25
                      The one I pulled from a 70c55 was 256gb.. Interesting that you haven't had issues with the 128gb version
                      • Hart
                        • Feb 2024
                        • 378
                        #26
                        HDD Capacity:
                        BP-50Cxx/ BP-55C26: 128GB SSD (STD), BP-60Cxx/ BP-70Cxx: 256GB SSD (STD),
                        Opt: 512GB SSD with BP-SD10
                        • Hart
                          • Feb 2024
                          • 378
                          #27
                          BCR4.5 (M6071) did not accept my SSD this morning.
                          • harps05
                            Field Service Engineer
                            • Mar 2012
                            • 111
                            #28
                            This is what I've been using:
                            https://www.amazon.com.au/Silicon-Power-128GB-Internal-SP128GBSS3A55M28/dp/B07BWBHZ94?sr=8-8&th=1
                            https://www.amazon.com.au/ORICO-SATA-Enclosure-Adapter-Smart-DDNV/dp/B0C2HB4N2Q?sr=8-5
                            Rip'd via Raw Copy Tool the same way as the CR4's. Takes a lot longer, but works fine.
                            • ihatefinishers13
                              • Feb 2020
                              • 680
                              #29
                              • Hart
                                • Feb 2024
                                • 378
                                #30
                                And ofc Sharp France doesn't communicate on this ...
                                RH-IX0379FCPZQ
                                354€
                                Seems legit
