What's your check list after unpacking
  • Hart
    • Feb 2024
    • 411
    After 5 years I've just realized that most of our machines haven't been properly configured and calibrated in the workshop by the person who's supposed to be looking after them, which has screwed up a lot of fusing belts...
    I'm going to have to create a checklist for him to attach to the machine after each visit to the workshop.
    Knowing that he has 1 hour max per machine, what do you advise me to put in this list?
    I've already removed the firmware update, I'll do it on installation.
    25-02 (if applicable) or 25-01 (if not) before installing toner
    06-08 (if applicable)
    50-10 MAIN-CSx
    50-05 DEN-C
    61-13
    61-11
    50-22 (if color)
    46-74
    Language and Keyboard in French
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 707
    Re: What's your check list after unpacking
    50-10 MAIN-CSx
    50-05 DEN-C
    61-13
    61-11
    50-22 (if color)
    46-74
    All of that looks good. Also testing every tray of the machine including duplex, and any accessories like fax/finisher/LCC. Firmware really should be done once all of the accessories are on, however, Sharp's aren't really as picky about it as some other manufacturers. We also have a couple settings to adjust from what we have experienced in the field, but that's typically set per dealer, and just prevents unnecessary callbacks.
    This being said, we haven't done any 6-8's ahead of time, and haven't had any issues with fusers, minus the usual issues.
    • Hart
      • Feb 2024
      • 411
      Sharp is really lax with firmware (while Epson wants us to update the firmware before and after the options are installed).
      Which settings do you usually do ? I keep forgetting to setup the automatic firmware update on the CR5.
      I check every machine with 06-08 now that I know he doesn't, one of the new machines last week was 2 click away.
      • copyman
        Owner / Technician
        • Sep 2005
        • 4709
        With Konica Minolta "i" series and all the issues, after unpacking you get on your knees and pray machine will even work
        • ihatefinishers13
          • Feb 2020
          • 707
          We change:
          26-35 to a 1 (BP's now have it already enabled)
          26-69 (For those who have maintenance) A-1, B-3, E-1, F-0
          55-3 22-5 to 1(not sure what it does but it's already enabled on BP's), and 32-2
          Copy Color mode to Auto
          Enabling A4/Ltr and A3/Ledger auto change (USA uses letter, legal, and ledger)
          5min preheat time, uncheck the "Turn off Panel..." option, set to 15 mine shut off timer, and fast wake up
          Change to Wired mode
          Add the ID tag of the machine and the customer name (and location if you have it)
          And add email alerts to our contracts email once every month based on the install date (in case other reporting methods fail)
          All of these can be changed in 2 minutes.
          • CroceL
            Sharp / Brother Tech
            • Jun 2020
            • 62
            Sharp contact told us with the release of Sphinx/Griffin/Phoenix (2630/3060/4070) we shouldn't do 25-02 anymore on first start up.
            Since then: (same for new Titan/Atlas)
            • Delete all Startup buttons, only Copy and Networkfolder Scan (unless we know what the customer wants already)
            • Energy mode 10min preaheat, Turn Panel off, 60min shut off and fast wake-up
            • Scan settings: Set all mono scans to grey standard
            • Connect everything and firmware update
            • 50-22
            • 46-74
            • 64-1 check with first 4 settings being 11-2-2-255
            • Done
            Titan/Atlas exclusive: Set Home button the right
            Can easily do 4 machines in 1 hour
            • Hart
              • Feb 2024
              • 411
              Originally posted by ihatefinishers13
              We change:
              "26-69 (For those who have maintenance) A-1, B-3, E-1, F-0"
              Not sure to follow this one, I just put F-0 (it's already on 0 since CR4), but we use the mail to manage our fleet instead of a real solution.
              55-3 SW-22 5 is to add the toner box on home screen (CR4 a new option appears in home_basic)
              I tend to leave the Copy Color mode to Color instead of Auto, too many complaints on the old generation, I've never tried on CR4
              I've never understand what "Turn off panel" does, can't see the difference when turned on or off.
              • ihatefinishers13
                • Feb 2020
                • 707
                We push the Color setting to Auto because if you copy 10 pages, and 2 of them are color, you can run it as auto-color, and it will only count as 8 BW and 2 color.
                • Hart
                  • Feb 2024
                  • 411
                  But ... we're loosing money :O
                  • ihatefinishers13
                    • Feb 2020
                    • 707
                    Well that's how we lose customers if they lose money :P
                    • Hart
                      • Feb 2024
                      • 411
                      Unless they don't know in the first place that this mode exists
                      "55-3 32-2"
                      I can't find any info on what 32-2 does, any idea ?
                      • ihatefinishers13
                        • Feb 2020
                        • 707
                        "55-3 32-2"
                        I think it was something to do with email status reporting. Don't quote me on that, though.
                        • boutn
                          • Jun 2016
                          • 547
                          "55-3 32-2"
                          Toner MIB report 5%
                          • Hart
                            • Feb 2024
                            • 411
                            Yes but what does it means ? What's the difference with 26-69 A ?
                            • ihatefinishers13
                              • Feb 2020
                              • 707
                              I believe it makes it report in 5% increments, so when you change 26-69 -A, it reports correctly. Idk, I think it's dumb that they put so many things as softswitches, it makes our job harder, and isn't like you can look up what you need since there is no master list; other than one we created.
