service mode on AR-m237 sharp... please help me!?!?!
  • youngblood
    copier janitor...=)
    • 18
    i've tried everything i can think of to get into service mode on this machine... i'm a kyocera\ricoh tech that just got forced into working on sharps so if anyone will please help me, thank you... i just need the code\procedure to get into service mode on this machine AR-M237 SHARP... and someone to tell me the developer initialization sequence\simulation. i'm P.M.'ing this machine...
    thank you all soo much,
    Cameron "youngblood" Webb
    Desert Office Solutions. LLC.
  • MOPARMAN
    • 5
    Sim Codes
    Hello, You'll also need to reset Maint., developer and drum counters if doing a full PM. to get in be sure you are in the copy mode-press the copy mode key located next to the main display then use what we call "P Star C Star" That is press Pound Key then Astrid Key then Clear Key then Astrid key one right after the other. Sim codes as needed are : Developer Calabration 25-2, Developer counter clear 24-5, Maint cuonter clear 24-4, Drun cuonter clear 24-7.
    25-2 for example from sim mode:
    press NO. keys 25, press copy start key, press NO. key 2, press copy start
    Hope this helps BE SHARP Man, Allen
    • jprecht
      • Dec 2008
      • 104
      sharp sims.
      MOPARMAN must be pretty sharp!!! he has given you all you need. if you have further ??? write. have all the sharps on disc.; jp P. S. i grew up in huntington park!!!
      IT IS BETTER TO REMAIN QUIET AND BE THOUGHT A FOOL
      THAN TO SPEAK AND REMOVE ALL DOUBT
      • ZOOTECH
        Senior member of CRS
        • 3375
        It is important to do a CA after 25-2 to store the toner concentration level. Then you can do the counter resets.
          • 22997
          I have started running the developer stir a couple times, especially if your readings are outside 90-110. I've got nothing else to add. =^..^=
          • djv
            • 27
            This came directly from sharp tech's, they claim this will also lengthen the dev life.
            Open front door and do the following
            sim 24-4 maintenance
            sim 24-5 dev
            sim 24-7 drum
            sim 24-11 reset drum and dev rotation/timer
            sim 25-2 dev initializing, you get the message door open and then close the door and hit start again
            since doing this procedure I notice I get 40-60k more copies from the developer
