AR-M350N
  • RSCA
    • Jul 2008
    • 112
    AR-M350N
    This machine has the 2000 sheet pedestal. It jams intermittently from the left stack. Never from the right. I have changed rollers, one way bearings (2), and the paper feed sensor. Paper gets about 4 inches out of the tray and stops. Any ideas? Thanks.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1887
    Replace it with the 3 tray desk. I've got one doing the same, replaced everything including the clutches on the back of the desk & transport rollers. PITA
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
      • 23009
      I wish I could offer you something more constructive. I had an AR-D13N paper deck with a similar problem.
      I had a scrap AR-D20 paper deck to swap parts. I swapped every single part but the frame, one item at a time. When I was done, both decks had the exact same jamming problem. We finally set it on an AR-D15 three cassette base. =^..^=
      • KyoceraChris
        • Jun 2009
        • 112
        their is an update on the pressure springs, have you tryed that?
        you gunna eat yo corn bread?!?
        • RSCA
          • Jul 2008
          • 112
          I found a bulletin that looks like it might be what you're referrring to.
          Number: AR-P350-054
          It refers to the left door follower spring.
          Does this sound like it and will this actually work?
          • KyoceraChris
            • Jun 2009
            • 112
            i would have to check sharpnet for the proper # , that was the fix i used on those copiers 6 years ago
