"EL error" on 25-2 sharp Ar-M237 Please Help!!!!
  • youngblood
    copier janitor...=)
    • 18
    I am a RICOH/Kyocera tech that got forced into working on a sharp 237. i performed a PM on the machine but after i added developer and ran the automatic DV adjustment it went down to "73" and said "el error" at the end... i've tried everything i could think of on this machine and i dont have any service manuals... is their anything else i can do without having to replace the DV unit??? please help me, it would be greatly appreciated.
    God Bless
    Cameron Webb
  • Dark Helmet
    • May 2009
    • 835
    remove the back cover, unplug the toner motor (2 black wires that are on a big white connector) put a piece of paper about 1 inch on the glass so your lead edge does not jam and run 20-25 sky shots. Run 25-1 and see were the developer is at. If it's around 100 plug the toner motor back in and run 25-2 again. Before starting the copier after plugging the motor back in make sure the front door is open, enter Sim codes, enter 25-2 then close the front door.
    Not sure if this is the best way to tatical this but it's worked before for me.
    • youngblood
      copier janitor...=)
      • 18
      thank you much... i'll give it a shot when i get there. do you need anything that i could help with????
      • youngblood
        copier janitor...=)
        • 18
        anyone else got any ideas that would help??? thank you...
        • DavePo
          • 303
          I would try taking out the toner sensor from the developer unit and wipe off toner buildup. They sometimes accumulate toner on surface and give false readings.
          • ZOOTECH
            Senior member of CRS
            • 3375
            After any dv adjustment (25-2) you must press CA key to store the toner sense level. The other suggestions from DavePo and Lawrence are good tips and should be done.
            • needlesgxe
              • Aug 2008
              • 30
              cleaning the toner desity sensor on the developer unit then running 25-2 worked great.
                • 22997
                Congratulations. =^..^=
