AR M160 E7 Error
  • Stefanobruciato
    • Jul 2025
    AR M160 E7 Error
    Hi
    My Sharp AR M160 has a problem when you use the scanner blocks is I must turn off and on whenever. I read on display the error E7.
    Where can I find firmware update?
  • JustManuals
    • Jan 2006
    • 9838
    What is the E7 sub code?
    Why do you think you need a firmware update?
    Paul@justmanuals.com
    • OMD-227
      You need to upgrade the MCU Firmware to v3.01.
      Then clean all optics/mirrors..... really well.
      If you are still getting E7-11 after this, replace the copy lamp assembly or ensure mirror base is parallel with mirror B or adjust CCD height by 1/2 turn maximum and check C/Q. Also check CCD skew.
        • 23008
        wazza,
        Doesn't the Pegasus have the same rectangular white mylar on the rear of the slit glass, that the Panther does?
        To see the rest of your error code press & hold the start button.
        If it's E7-11, and if it occurs only when using the SPF (document feeder), then very likely the white level reference patch has peeled off, has dirt under it, or is just plain missing. Some techs just paint the 20 x 25mm area on the rear underside of the slit glass with white out. Personally I prefer to cut out a little rectangle of white report cover and adhere it around the edges with two sided tape.
        • OMD-227
          Yes, all Sharps that I can remember at this moment have the white ref under the slit glass. Never seen one peeled off though as yet. Good one!
          I got the info supplied from our B/W guys. They seem to think this is the fix.
