Sharp AR 157e
  • vstar
    • Aug 2007
    • 176
    Sharp AR 157e
    Would anyone happen to know what you need to do, to set up developer on one of these. We don't normally work on Sharps, but a customer called and it needs the dv unit replaced. We have the developer on hand but I am not sure what sim it is to do setup. Also, will this clear the lite on op panel.
    Cameron
  • tmaged
    Owner/Service Manager
    • 1866
    There is no DV set/stir on these. 20-1 resets maint. 24-6 resets DV counter, 24-7 drum.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
      • 22996
      Like tmaged says. Vacuum the developing unit out clean, and pour in the new developer. Reset the counter simulations listed and you're good to go. =^..^=
      • vstar
        • Aug 2007
        • 176
        Thanks guys, that really helps.
        One more question, do you get in to sim by C- interupt, 0- interupt, or some other way?
        Cameron
        • tmaged
          • 1866
          PM Sent
          Hope that helps !
          -Tony
          www.dtios.com
          • vstar
            • Aug 2007
            • 176
            tmaged
            Cameron
