L4-02 on ARM 455
  • vincent64
    • 382
    L4-02 on ARM 455
    I have a AR 455 giving this code, having checked the drum unit, its turning free, nothing broken, less then 200K on the machine, not even reached the first PM yet, sharp net says to replace the main charge unit.
    Has anyone else seen this, both main motor and drum motor both turn with no prob.
    Sometimes it will power up and run with no code, other times the code pops up.
    Any ideas???
  • patwilf
    Service Technician
    • Nov 2009
    • 41
    L4 02
    I had this the other day. I know you said there was nothing broken but i found the gear that drives between the two augers was broken. Toner stayed compacted in the drum unit. And if you are in a pinch you can use a AR M350 Drum Unit to do the repair. I haven't heard any problems from it yet..... You might check the gear drive too.
    • vincent64
      • 382
      I checkd all that, all 3 gears were turning, nothing felt binding, I'll re-check it, and even replace the drum unit to test.
      • patwilf
        Service Technician
        • Nov 2009
        • 41
        ok
        either that or the motor could be defective....and to make myself a little clearer...you can use a ar m350 frame but not the unit...............if i think of anything else i'll post it.....
        • OMD-227
          L4-02 is definitely the MC unit at fault. It is caused by an arching, and mainly happens on warmup.
          If the drum & waste toner augers are rotating freely, replace the MC unit. Might as well do the PM kit (including MC grid/unit) & drum at the same time. Make sure firmware is up-to-date and the rotation counts are reset as well.
            • 23009
            I'll have to side with wazza on this one. The times that I've gotten this code it was MC loss due to arcing from the primary charge high voltage lead (which is part of the main drive assy). This is common on Tigers and Jupiters. It is rare to have an actual drum motor failure.
            • vincent64
              • 382
              Will be going there this AM.
              Will try swapping out the drum unit.
              I had picked one up before going out there the other day, did not use it because the old drum unit seemed ok.
              Will keep posted
              • Dark Helmet
                • May 2009
                • 854
                Gona have to go with the master on this one to:
                One day i thought i'd try to double the life of the 455KA Drum kit. After doing the PM, (Drum, Blade, DV) i got called back like 2 days later for that exact code. Power cycled the machine and it went away but came back next day. Changed the charger and problem went away. Ive had guys tell me they have never done the 455KA kit yet and the machine has a million copies on it. Dunno how they get away with it.
                • DanielNM
                  • Nov 2009
                  • 19
                  L4-02 Error Code on AR-M455n
                  Were working on the same problem. I have talked to a couple of other techs and typically they have found either the MC Unit, the Main Drive Unit, the Devoloping Unit (Binding) or the Gears Broke in Toner waste removal section that have caused the L4-02 Code. We have Replaced the MC Unit, Toner Motor and are still getting the Error Code. The Developing Unit rotates smoothly. we have not found any Broken Gears. At this point we are wondering if the actual Main Motor or the Main Drive unit may be causing the Error Code. Any Postive Feedback ASAP would be Appreciated! Thanks! Daniel
                  • vincent64
                    • 382
                    Found out it was the developer unit, funny thing, the SM does not say anything about it, it refers to the drum unit, and I did not think to check the developer unit bacause I like others have seen the drum unit lock up, break gears, M/C arc and cause problems.
                    Only one other time have I seen a DV unit go bad in these machines.
                    Its on order.
                    • DanielNM
                      • Nov 2009
                      • 19
                      Thanks! We will double check the Developer.
                      • TechGeek
                        • 158
                        Just an F.Y.I.
                        I have also found that in the main drive gear assm. there are two gear located at the top that the shaft the gears spins on has old dried up grease and was binding up the drive unit. I took the main dive unit apart ( a Pain in the rear) and cleaned and lube. Works good.
                        • DanielNM
                          • Nov 2009
                          • 19
                          We have already ordered the Main Drive Unit. Should be in Today. I have also heard it's a pain. About 2 hours or so to change it. I'll let you know how it goes. Thanks! Daniel
                            • 23009
                            Start by removing all the consumable units: drum, dev., fuser, reg unit, delivery/turnover. Then back cover, left side door assembly, and the left door's rear rail. The rest should be simple enough to figure out.
                            My best advice is don't rush re-assembly. Make sure you get all the connectors back where they belong at every stage. Otherwise you'll be back in there digging for loose connectors. =^..^=
                            • lky1978
                              • Mar 2009
                              • 483
                              Check the waste toner transport gear that in rear drum unit.may be tight and stuck by waste toner
