Difference between AR-D14, AR-D15 and AR-D27
  • sgpm
    • Sep 2008
    • 16
    Quick question :-)
    What is the difference between these 3 x 500 sheet paper drawer stands and which one (or more) will work with the Imagistics 4511 copier?
    Thanks a lot,
    Greg
  • bilyahn
    • Dec 2006
    • 1468
    If this post is correct:
    Then you have an ARM355/455 series machine and need the ARD27 unit.
    The ARD15 is for the ARM350/450 series. Couldn't tell you what the differences are.
    Hope this is helpful.
    Good luck.
    Bil
      • 22942
      Mechanically they're the hard to distinguish. It's the boards that are different.
      • sgpm
        • Sep 2008
        • 16
        Thank you both for the replies. I'll order the ARD27 and see how it goes.
        One more question for the IM4511/AR-M455. :-)
        When inserting a pre-printed cover (color) does the cover sheet go through the fuser or through a separate path? Exit tray is that of the booklet finisher (FN7).
        I tried this once with an AR-M450 (thought I manually added the printed cover in the same tray as the other sheets since the old tiger would not let you add a cover in booklet mode) and the result was well... not very pretty!
        Greg
        • bilyahn
          • Dec 2006
          • 1468
          It will go through the fuser. This series does not offer and add-on inserter like the ARM550 series does.
          Bil
