Sharp AR M207 "E7-11"
  • mlbcopiers
    • Oct 2007
    • 34
    I have a customer that is using the scanner on the Sharp AR M207. Every time they try to scan a document the copier gives an "E7-11". It doesn't mater if it is from the feeder or on the glass. I have cleaned the under side on both sections of the glass, and added extra white tape. The copier portion/operation works fine. Never a code.
    Once in a blue moon, the copier will scan after a few tries, and sometimes if you choose black/white.
    Someone said to update the "FIRMWARE". Is that with in the copier, or a patch to the driver on the computer. How do you update the firmware if it is on the copier?
    Any help will be greatly appreciated.
  • travi
    • Jan 2008
    • 129
    The firmware is a control program for the machine. It requires that you download the new program file and the maintenance program to install it from Sharp's service website. The procedure is explained in section 12 of the service manual. If updating the firmware does not work try replacing the CCD. I have had to do that in the past.
    • OMD-227
      Firstly, the firmware must be updated. The firmware version with the E7-11 fix included is v2.05 MCU.
      You must clean all optics, mirrors and copy lamp reflector.
      If you still get E7-11 codes after this is done, you must either:
      Replace the Copy lamp assembly.
      Ensure mirror base is parallel with mirror B.
      Adjust CCD height by half-turn maximum. Also check CCD skew.
      • digivision
        • Aug 2009
        • 44
        dear all, can i have FW for arm 207 ,i have all toshiba FW,if anyone want 2 shear pls rep. me
        BR
        • pioneer007
          • Oct 2009
          • 37
          BR
          What?
            • 23008
            I think he's looking to trade. =^..^=
            • spotlifter
              • Mar 2008
              • 65
              BR
              Here's the correction:
              " Dear all, can I have the firmware for arm207? I have all the toshiba firmwares. If anyone wants to share, please reply me. "
              sigpic
              • digivision
                • Aug 2009
                • 44
                hi dear travi,
                i need to update fw of arm 207 copier, can i have fw file for arm 207,if u can pls email me digivisionm@gmail.com.
                thanks in advance
                BR
                • Scijohn23
                  • Sep 2009
                  • 91
                  Here is a dumb question, Does the machine have the slit glass installed. I had this problem once and someone had just thrown a df of the machine and didn't install a slit glass.
                  • costd
                    • Jan 2008
                    • 409
                    That would be funny if we did not have someone that (on a Canon) swapped an A1 and B1 but did not switch the end plates - then called Canon because it kept jamming. lol - unless it happens to you.
                    • OMD-227
                      If that was the case, someone is in the wrong career.
