Ar-m620 printing problem
  • swagreis
    • Jun 2008
    • 92
    I got a ar-m620 model but i can not use it as a printer
    i entered KEY-OPERATOR programes but there is any menu for printing although in other machines of the sames model have these menues so it can print easily.
    Is there any solution for that problem ?
    • 23010
    Do you have an AR-M620N or an AR-M620U?
    The 'N' version is networkable. The 'U' version is not networkable without replacing boards.
    • swagreis
      • Jun 2008
      • 92
      the model is AR-M620U
      • bilyahn
        • Dec 2006
        • 1470
        Since you have the "U" version you will need to get the ARP19 network expansion kit to be able to print. The kit has 2 ROM's and a NIC card plus the paperwork to enable the "key" for printing.
        • swagreis
          • Jun 2008
          • 92
          is there any another way for solving this problem
          like copying rom's and do another step for simulating product key!!!!
          • tmaged
            Owner/Service Manager
            • 1898
            No other way around it than buying the P19. The USB & Parallel ports on that machine are ONLY active when doing firmware updates.
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
              • 23010
              I don't think that you're listening, swagreis. I'll make this very succinct.
              Not free.
              Must but parts.
              • mrpolitics
                I have the AR-m629n and I cannot get it to print, it keeps printing out a sheet reading sent from Unknown, and a file name filled with random numbers. The print job is never printed though. I am using LPR.
                • bilyahn
                  • Dec 2006
                  • 1470
                  I have had this happen when we installed a Sharp with the same IP address as the previous Canon copier it replaced. For some reason the Canon driver would just print out a lot of pages of junk. Also there is a firmware upgrade that address' this issue as well.
